Home > Tdi > 300Tdi - seems to be leaking from the distribution head
rlynch356
United States 1995 Defender 90 V8 Petrol ST Alpine White
is it possible to change the seal without taking the pump out? trying to figure out my options.
It leaks a lot if I crank the engine for any amount of time (like say when its coldin the morning) but does not seem to leak when running.
it is leaking directly below the distribution head on to the oil filter.
Post #879652 20th Jan 2021 7:28am
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
IIRC the oil pump is mounted on the crank at the front of the engine, so I see no reason why you couldn't take the oil filter housing off to change the gasket. Would be an idea to thoroughly degrease the area to check exactly where it's leaking first as there are quite a few oil connections in that area.
Post #879703 20th Jan 2021 1:04pm
Oldowner
It is far easier to remove the injector pump to replace the distribution head o ring - only takes ten minutes if you have the pulley retaining tool in the timing kit.
There was a revised injector pump rear mounting bracket which is well worth fitting if you do remove the pump - it positions the pump correctly ans prevents the timing case flexing when the injector pump is reinstalled and bolts torqued up.
What I would say is don’t fit the revised bracket without changing the oring as the bracket will hold the pump in the exact correct position it should be in, if it has been slightly out of position for the last twenty years then the slight change in position will then cause the old o ring to leak!
In the uk the timing pulley kit is £20-£30 and the revised bracket is usually around £10.
Post #879854 21st Jan 2021 5:32am
Horneteer
Ah so we're taking fuel leak out of the injection pump rather than oil leak? My bad...oops.
Post #879994 21st Jan 2021 7:26pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Whats actually leaking ? oil /water or Diesel? the oil filter is no way near the front of the injection pump,,,
Post #881480 28th Jan 2021 1:17am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Anyone know the part number for the revised pump mounting bracket ? Rebuilding a 90 & 110 300tdi at moment and would like to reduce every future problem
Post #881641 28th Jan 2021 10:08pm
Martin
Site Admin
Insulting posts removed from the thread.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #881642 28th Jan 2021 10:13pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Here you go: https://www.lrworkshop.com/parts/ERR6835 LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #881646 28th Jan 2021 10:30pm
Moneypit
Thanks for that, your a gent
Post #881654 28th Jan 2021 11:16pm
