![]() | Home > Maintenance & Modifications > Mud heater deflector - any pics when fitted? |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Maybe it's the hot handbrake you like
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 462 ![]() ![]() |
I don't have a problem withthe standard set up tbh.
If my leg gets hot, I know its all working ![]() |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 242 ![]() ![]() |
I’m with Badger I get cold feet and a hot dash with mine, must get round to removing it, or was thinking about putting a small elbow or vane in to direct heat down and cutting a bit off the lower edge... 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Ooh err missus. Close to tip polishing territory WARNING. This post may contain sarcasm. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4810 ![]() ![]() |
On the early Puma the heater is an all or nothing affair and the passenger footwell side blows hotter than the driver's footwell. I fitted one of these to a 2008 Puma as my wife's leg developed a bad rash from the heat going into the passenger footwell. 1982 88" 2.25 diesel
