Home > Wheels & Tyres (L663) > Larger diameter tyres & computer/speedo
Cheshire110
Is it possible/necessary to tell the computer if you’re running larger diameter tyres? To correct the speedo, trip computer etc? Given that everything is electronic anyway you’d think so... Cheers, David
Post #878305 13th Jan 2021 7:48pm
hotwheels
Yes would also be interested as I’m going from 18” to 20”
Post #884070 9th Feb 2021 6:09am
Simon Audi
If you are staying with standard factory sizes of the 18" and 20" tyres then the outside Diameter is 32" and rolling circumference are the same - so no need to worry on speedo . I think you can increase to 33" max (maybe some rubbing)
This is 103.5 inches circumference compared to 100.5 inch circumference - so a 3% increase...
Not worth adjusting anything for in my opinion.
Post #884078 9th Feb 2021 7:44am
SN
that 3% might drag you into a conversation with plod though...
On a related question does anyone know how "accurate" the Defender speedo is?
My understanding is that speedos are generally 'over calibrated' - i.e. show higher speeds than you are actually travelling at (to save you from yourself I guess?)
On my previous vehicle my approach relied on having a separate GPS speedo visible on my SatNav screen for accurate readings allowing my traversal through 50mph Average Speed Camera zones at a GPS registered 52mph (i.e. within 5%) with In-Dash Speedo reading about 57mph.
I'm assuming the built in Pivo Pro / Digital Dash will continue with the 'over calibrated' approach? Anyone know? Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #884130 9th Feb 2021 12:17pm
21Rover
Australia
My speedo appears to show around 3km/h faster than actual speed between 60-100km/h. Or 2mph between 40-60mph. Measured by gps. ■ MY21 110 D300 SE ■ MY17 Jaguar F-Pace ■
Post #889815 8th Mar 2021 11:25am
SN
Useful site if you're worried about tyre and rim sizes
https://tiresize.com/tyre-size-calculator/
I was looking at 255/70R18 Duratrac's on a set of 2nd hand 18" rims
But have settled on 255/65R19 Duratrac's on the existing stock 19" rims I have already bought
Although they're both declared at 32.1" diameter it appears that over every mile the 19" tyre will turn 630 times rather than the 629 times of the 18" tyre - so a difference of 0.01% - no impact on speedo or plod-vulnerability Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #890250 9th Mar 2021 5:33pm
