- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Packster82
Hi Guys, my passenger side wiper has suddenly lost its sync and is moving at a different speed to the drivers side, which is working fine. It is going beyond its park position and beyond its usual arc range. Would i be right in assuming the passenger spindle has likely lost its teeth and the wiper is slipping?? The wiper motor went in the summer which I replaced so regretting not doing the spindle at the same time if that's the culprit!!
I looked at the spindle earlier and the nut at the end just turns the whole spindle so seems completely seized, so any advice on how i might be able to release this would be really helpful. Cheers!
28th Dec 2020 4:27pm |
