Home > Maintenance & Modifications > Uneven pad wear - AP brakes
Likeomg
Been doing some routine maintenance on the truck, new the pads were low
Anyway - completely free moving pistons but one pad with 9-10mm of material and other 2-3mm,
Any theories? could it just be the calliper isn't very well aligned on the disc? something else? my initial thought - seized calliper but it's both rears and both sides are free moving.
Post #874202 22nd Dec 2020 7:29pm
Dinnu
Did you check wheel bearing? maybe allowing the disc to come in contact with one pad more than the other?
This is very common on other cars that have pistons on one side of the caliper only, but happens because the caliper is not free moving in its guidings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #874203 22nd Dec 2020 7:33pm
jst
lower on the side the fluid enters? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874206 22nd Dec 2020 7:36pm
Likeomg
Wheel bearings are good, just did a seal too.
yeah jst, it's the side the fluid enters from
They are uprated AP racing brakes too, 4 pots on the rear
Post #874210 22nd Dec 2020 7:57pm
Retroanaconda
This always happens with rear brakes in my experience, particularly when people have removed the splash guards.
Post #874214 22nd Dec 2020 8:23pm
90 Dreamer
Is the caliper centred correctly on the disc??
Post #874215 22nd Dec 2020 8:26pm
Mo Murphy
As James has said, common on rear calipers with no shields.
50 Shades of Pennine Grey
Post #874219 22nd Dec 2020 8:33pm
Mo Murphy
Post #874220 22nd Dec 2020 8:33pm
Likeomg
Never knew about the rear splash guards, is there a theory behind it?
I didn’t fit the callipers but there isn’t any adjustment I don’t think, just adapter plates and that’s it...
Post #874221 22nd Dec 2020 8:36pm
jst
Whether its in centre or not is irrelevant.
Shields make a difference, side with fluid input always seem to wear quicker. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #874236 22nd Dec 2020 10:07pm
Likeomg
Just seems such a large difference, will keep an eye on it in future.
Post #874237 22nd Dec 2020 10:12pm
