![]() | Home > In Car Electronics > Relay Removal |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Big hard wobble and pull required.
| robrennie Member Since: 20 Mar 2018 Location: Somerset Posts: 28
Thanks Daz - all the confirmation I needed!
| llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151
If you just give it a hard pull you may pull the socket out the fuse box and even the wires out the socket ( talking from experience ) I now opt for a gentler approach and try to get a flat bladed screw driver in between the relay and the socket to gently prise the relay away from the socket until it becomes easier to remove. The clips on mine were on the socket and located on lugs on the relay, again a thin flat screwdriver eased them up over the lugs.
Click image to enlarge You can just see the lugs on the side near the base - the above image being the two pin ie Dim Dip defeat version of the relay |
Thank you llessur - I opted for a small broad flat screwdriver - with a a bit of a wobble - it did come out
Out of interest - that looks like the bypass relay you have fitted - did you fit that to a TDCi? |
Yes it replaced the original as I had trouble with the Dim Dip option after I fitted LED lights. Though at £20 off fleabay it was a waste of money as I read on hear that I could have just unplugged the resister "thingy" under the drivers side wing, bit further down towards the front from the wing mounted aerial base.
Thanks
I have just posted separately on here about the topic! - I took out the pink relay, but it has an awful lot of connectors on it - I was expecting it to look like the relays from previous versions, 4 or 5 connectors. Can you recall what the relay you replaced looked like? |
Here you go
Thanks!!!
Perfect - I have the same relay, so I have ordered the right bit! I appreciate your help Merry Christmas |
Have a look at this if you fancy making your own dim Dip relay defeat
https://www.landroverexpedition.com/techni...dip-relay/ |
Just to close this off.
Fitted as per advice the Dummy Relay and all works perfectly. Part Number: YWZ10003L Thanks All. |
| All times are GMT |
