Home > Td5 > Replacing clutch |
Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80 |
Fitted the plate backwards? Or maybe the slave not engaging with the clutch fork. 2003 Defender 110 TD5 SW
2003 Caterham 7 2006 Mini Cooper GP |
9th Dec 2020 4:28pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
As Paul says plate in wrong way round. When plate fitted correctly it looks wrong in comparison to normal clutches, dont ask me how I know this.
I had a driven plate, that was marked this side to flywheel on both sides, which helped a lot |
9th Dec 2020 5:05pm |
Dixy Member Since: 30 Nov 2020 Location: Somerset Posts: 42 |
Thanks gentlemen, it is what I had feared, not that the box is heavy or tricky to slide in or out on a trolly jack.
OK so for avoidance of doubt and because Valeo could not be kind and put fly wheel side on the plate. The plate is effectively flat on one side where the spline is but the other side has a top hat. Should the top hat side go to the fly wheel. |
9th Dec 2020 6:37pm |
The greater projection of the centre hub on the clutch friction disc must be towards the flywheel. Both RAVE and Haynes state this and it is generally how most clutch plates are installed. As already stated some of them have a stamp indicating the flywheel side. The old OEM disc I took out has the stamp so have a closer look. Mine is stamped FW.
9th Dec 2020 8:12pm |
Thank you both for your help, only wasted many hours taking the box off, removing cover, turning plate and replacing. Clutch now clears.
I wish I could say lesson learnt but like most I only read the manual when nothing else works. |
10th Dec 2020 12:30pm |
Glad it's sorted, it's an easy mistake to make, thankfully the vehicle I made the error on was a little bit easier to rectify! 2003 Defender 110 TD5 SW
10th Dec 2020 7:41pm |
