Home > Td5 > Td5 380 gearbox question...suffix J or suffix L
Patagoniazed
Chile 2000 Defender 110 Td5 SW Aintree Green
Hello!!! I have a late 99' Defender 110 Td5 and in need of a new gearbox. Searching the market, I've found two types of 380 gearboxes available, one for Suffix L gearboxes and Suffix J.
The original gearbox did not come with a serial number on it, it is just not there, not wore out, not erased...just blanked. (you can see that in the picture)
the box does not have an oil cooler.
Which gearbox should I get? I've already asked several sellers, such as Ashcrofts or Bearmach, but they havent been able to point me in the right proper direction.
I live in southern Chile, there is no Land Rover dealer here.
HELP!!!
[/img]
Post #870590 30th Nov 2020 8:33pm
The suffix J is correct for the year of your Defender but the suffix L is essentially an improved version (bearings, gears, etc.) and should fit anyway., Darren
Post #870638 30th Nov 2020 10:40pm
ashtrans
Site Sponsor
Hi,
all TD5's were K or L, never J Dave
Post #871151 3rd Dec 2020 5:21pm
Patagoniazed
The remaining question is....should I get the suffix L gearbox then?
Would I have fitting problems?
Thanks in advance !
Post #872340 10th Dec 2020 7:51pm
ashtrans
Site Sponsor
if its a TD5 you will have to get suffix K or L, any J won't have the TD5 pinion and thus won't fit,
the TD5 Defenders had the type 68A R 380 fitted, thats the one you need to find,
we can supply if you can't find one, Dave
Post #872345 10th Dec 2020 8:38pm
