![]() | Home > Maintenance & Modifications > Spafax Mirrors |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I asked about replacement mirrors as the standard and larger set were very underwhelming.
I was advised on Spafax Mirrors and i took the advice and bought a set. Well made and clamp very tightly with zero movement while travelling at high speeds of 60mph or thereabouts ![]() They are about the same size as the original mirrors but are convex so give you a better field of view, but make the rear of the vehicle further away which take a little get used to. I purchased mine from Ebay as it was the best price i could find, links are VM3 Spafax 205mm x 150mm https://www.ebay.co.uk/itm/SPAFAX-VM3-Univ...2749.l2649 You will need 2 of these VM6 KIT's https://www.ebay.co.uk/itm/Adapter-Kit-for...2749.l2649 Message the seller as they'll sort out the postage costs ( i think i paid £17 ) £75 all in for a pair of indestructable solid mirrors. Well worth it ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2380 ![]() ![]() ![]() |
Excellent, I'm really pleased with mine
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
I had a set of heated Spafax mirrors for years but removed them last year and went back to the oversized OE style (which in one form or another I had been using for the previous 15-years).
![]() The Spafax were ok and field of vision wise compared well with OE mirrors but were smaller than the oversize ones I was used to. That wasn't a problem as they still gave a good field of vision but it was the nightime vision that put me off them. At night it could be like looking into an auto dipping rear-view mirror where you get a double image (a ghost image if you like), not a problem 99% of the time but if you wanted a crystal clear image in the dark then you couldn't get it. One place the Spafax did win was by moving the mirror rearwards. I have Climair deflectors fitted and the OE mirrors sit slightly too far forward with the edge being obscured by the deflector, the mounting of the Spafax moved them back a little meaning you got to see 100% of the surface. In the end I removed the Spafax and put them at the back of the shed (just in case I ever decide to give them another go). Just a shame I sold my original mirrors as I had to make up a new set of oversized heads with heating elements! ![]() Click image to enlarge ONE LIFE, GET IT! |
