Home > Faults & Fixes (L663) > Coolant Level Low
denhams
United States
Coolant Level Low
I'm getting an intermittent coolant level low warning. It clears itself, sometimes in a few minutes, sometimes the next restart. The coolant level is fine, fractionally above the 'Max' level.
Has anyone else experienced this? I guess it will mean a trip to the dealer. 1981 Series III 88 Santana Especial
2020 Defender 110 SE
2023 Tesla Model 3 RWD
Post #869166 23rd Nov 2020 5:34pm
vlad
Romania
Probably a dirty/faulty sensor. MY2021 Defender 90 P400 SE
Post #869179 23rd Nov 2020 6:43pm
Florida Rover
United States
I had this same coolant error message within the first 500 miles on my First Edition P400. I read from one of the Facebook New Defender Groups that it's been a known issue. According to several on the group, "The coolant needs to be "burped." Apparently air bubbles can be trapped in the line and the level sensor notes this as an empty reservoir? So very carefully open the coolant cap when the car isn't too hot but warm. From there it should let the air bubble out and be good." I followed this guidance on mine and haven't had the error since. My coolant reservoir was always close to max level by visual inspection as well. I'm now at ~4,000 miles on and off road driving and 2 full months of use with no additional coolant level error message. Hope this helps.
Post #869217 23rd Nov 2020 9:14pm
denhams
United States
Thanks. I shall try that first. I also found this https://static.nhtsa.gov/odi/tsbs/2020/MC-10179507-0001.pdf searching the manufacturer communications on the NHTSA site. 1981 Series III 88 Santana Especial
Post #869260 23rd Nov 2020 11:06pm
Florida Rover
United States
Good to know! Thanks for the link
Post #869271 23rd Nov 2020 11:41pm
I wonder if the two cable ties are a temporary solution whilst they work on a permanent one, or it's the permanent solution itself?
Post #869338 24th Nov 2020 2:16pm
