Home > Technical > Brake Query
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Brake Query
Folks, My brakes work effectively most of the time. They have however recently developed a tendency to be spongy on first press (every 2 or 3 time) but when pressed again all is well.
Had different views on this. I thought maybe some air in system, others said master cylinder (all looks ok).
ps. I noticed a slight leak at driver rear brake pipe a couple of weeks ago but when tightened the leak stopped
Views pls Sweaty...thanks in advance Sweatysock
110 CSW TDCI (Puma) 2007
Post #81928 25th Jul 2011 10:03pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
hmmm, you have sucked air back in the pipe.
i would just bleed the whole vehicle and that would change the fluid as well - quite quick and simple. BM52
Post #81931 25th Jul 2011 10:10pm
landy andy
Wheel bearing???
Start with a pad check, then a bleed.
You could use a pipe clamp on one flex pipe at a time, to check the different calipers.
Andy
Post #81932 25th Jul 2011 10:10pm
bm52
Post #81939 25th Jul 2011 10:46pm
sweatysock
Thanks guys, I am going to look at both Sweatysock
Post #82339 28th Jul 2011 1:05pm
