![]() | Home > Puma (Tdci) > What springs |
110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 93 ![]() ![]() ![]() |
Running an 08 puma 110 hardtop need to change rear springs can't tell what's currently fitted as so corroded but rear is very harsh most spring see on line are all heavy duty rarely load it up so wanted to fit something to take the crashing down a bit will td5 progressive work anybody
out there changed hard top to something softer any advice appreciated Iain Endeavour To Persevere |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
I wonder if you have stock HD springs? I think general consensus is to use the 110 SW spring, (someone on here will know the part number), if you're after OE. Or use the Alive springs made by Eibach if you want something a little better. Not sure about how much difference there is between Td5 springs and TDCi apart from the latter no longer being 'handed'. They're both very cheap, so not the best, but there's a noticeable gain with the Alive set up. I suppose ultimate usage will impact your decision... Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
On my USW, I swapped the standard purple/brown springs for the dual rate white/green/green station wagon version, which are much more pliant when lightly loaded. The different weight of a hardtop means you wouldn't get exactly the same result but you would still see a benefit for not a lot of money. Darren
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
The springs do help but for maximum effect you'll also need to change the shocks for Koni Raids or similar adjustables
![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
