Home > Off Topic > UK’s first stainless steel bridge completed
Page 2 of 2 <12
"The chosen concept is essentially a bowstring arch with a top tie; a design that is similar in its structural behaviour to a half-through arch, says Beade. It is a composite structure, with both deck and arch formed of concrete slabs, connected at their edges to a stainless-steel structure with spandrel columns at right angles to the axis of the arch.
The arch and the deck become a single unit over the middle third of the bridge, and this, combined with the wider deck at midspan, creates the structure’s elegant geometry. At the centre of the span, the edge of the structure is only 600mm deep and at the ends of the bridge this increases to 3.1m.
The stainless-steel shear studs that connect the concrete deck to the steel structure to make it a composite were specially made by the steel fabricator. “We could have ordered them from a supplier in the US,” says Mitchell, “but it would have taken too long to import them.”
Duplex stainless steel was selected not just for durability and maintenance reasons, but also because its strength-to-weight ratio enabled a lighter structure that could be lifted into place as a single piece."
[Duplex 2205 - https://www.wec-group.com/news/pooley-brid...pdate.html]
[Stainless steel construction photos https://www.flickr.com/photos/wecgroup/sets/72157712802613928/
https://www.theconstructionindex.co.uk/new...les-bridge
And to bring it onto topic (for this forum) - how about a group buy for some stainless steel sand tracks? Whistle
Post #864399 30th Oct 2020 12:18pm
RFT wrote:
I too am interested in the use of Stainless Steel in the bridge, I have earned a lot of money over my career dealing with cracked and corroded stainless steel.
The grade of SS used, the welding details and post welding heat treatment and the loads on the sections will be of interest. Our natural environment and run off water from roads is full of salts and chemicals that may enjoy ruching through a stainless steel fabrication.
"Duplex stainless steels are increasingly used as structural materials in building and architecture because of their exceptional mechanical properties.
Their room temperature yield strength in the solution annealed condition is more than twice that of standard austenitic stainless steels not alloyed with nitrogen. Over the last few years, they have started playing an increasingly important role in the construction of bridges, wherever specific environmental conditions combine with the need for high load-bearing capability. Duplex stainless steels are mostly selected because of their combination of high strength and corrosion resistance.
Their full potential is used in locations where the material comes into contact with salt water, or where high concentrations of chlorides are present in the ambient air or where de-icing salts are of a concern. The higher initial costs involved in choosing duplex stainless steel as compared to conventional structural steel are more than compensated by longer life span and significantly lower maintenance and repair costs.
Their full recyclability makes them more sustainable than non-metallic solutions. Several recent examples of using duplex stainless steels in bridge construction are presented."
https://www.worldstainless.org/Files/issf/...ridges.pdf
Post #864403 30th Oct 2020 12:45pm
sako243
Makes me wonder whether a Brunellian approach would be been simpler / more appeasing (i.e. overengineer the damn thing)...
My company did some work quite a few years ago building a custom 512 channel data logger that was to be attached to 512 kilometres of strain gauges. The company that bought it were commissioned to do some fatigue analysis on two bridges somewhere near Newcastle. One was a recent build (had been built 3 years previously), the other was one of Brunels. British Steel loaded up and weighed in a 3,000 tonne train to within a gram and spent several days running it back and forth over the bridges to generate the stress cycles.
Conclusion - the modern bridge was condemned, Brunel's was good for at least another 100 years provided nothing catastrophic happened to it and painting was kept reasonably on top of. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #864757 1st Nov 2020 1:32pm
Just came across this and thought others may be equally intrigued :
Mashable (@mashable) Tweeted:
Watch as a stainless steel bridge is 3D-printed in mid-air https://t.co/UyQnmDXrSu https://twitter.com/mashable/status/1254965308105854977?s=20
Post #898654 16th Apr 2021 5:42pm
Double post.
Post #898655 16th Apr 2021 5:43pm
Page 2 of 2 <12
