Home > Off Topic > widonws 10 2004 will not run rave
Page 2 of 2 <12
ARC99
I had Dymo label writer and label maker running fine until the latest update they would run even though |I could see them and the trouble shooter said nothing was wrong, tried everything I could think of, run as administrator, comparability, virtual nothing made a bit of difference. I uninstalled the programme rebooted the PC and put the programme disc back in more in hope than expectation . Do you want to run programme in windows 7 or 8 ? well blow me it worked even did a search for any old label files on my back ups Drives. Don't make old people mad.
Richard
Post #865744 6th Nov 2020 5:54pm
AMBxx
Other thing to try is to disable UAC. You can search for it in settings.
Microsoft have done a huge amount to improve the security in Windows. If an old program tries to access memory in an insecure way, it will be blocked.
Post #865821 7th Nov 2020 8:20am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Having "upgraded" our PC to Windows 10 in January, this morning I'm rejoicing as I've finally managed to get our old Windows Live Mail working again. My goodness we've missed it.
The new Mail program included with Windows 10 is a ghastly, clunky mess. We tried OE Classic (a scam, all our emails were repeatedly hacked almost immediately), and Thunderbird (okay, but not as nice as WLM), so to get WLM back today is bliss.
The only trouble is, our PC is ailing, we've bought a new one ready for when it dies, but I don't know if I'll be able to get the old WLM onto it.
My 'O' Level in computing from 1980 isn't much help these days....
Incidentally, if anyone has had the same problem with losing WLM, I solved it using the details here:
https://www.tenforums.com/browsers-email/1...pdate.html
Post #865840 7th Nov 2020 10:06am
ARC99
WLM is no longer supported and as far as I work out will not run on Windows 10. On your old PC try running outlook and logging in with your WLM email address. Don't make old people mad.
Richard
Post #865850 7th Nov 2020 10:31am
Joe the Plumber
I'm sure it will run on Windows 10, as I'm on Windows 10 now and it's working fine since I used the fix in the link, above. I know it isn't supported any longer, but until it permanently expires, I'm going to use it as it's so good compared to its successors.
Post #865886 7th Nov 2020 2:24pm
I have W10 here on my laptop, and RAVE works just fine with its original Adobe software.
Maybe I'm just on borrowed time Shocked
Post #865945 7th Nov 2020 7:24pm
dorsetsmith
problem started when up dated from win 10 1909 to win 10 2004 but can run rave if you run in win 95 compatibility mod and original Adobe 4 software with this rave is written to work with win 95 and as other member have sad Microsoft have been making big changes to win 10 security with will stop older programs from running
Post #865959 7th Nov 2020 8:00pm
ARC99
I Had a problem yester with Windows preventing me from uploading a scanner programme , the PC was running windows 10 version 2004 , the agent from Microsoft suggested that I update to
Edition Windows 10 Home
Version 20H2
Installed on ‎01/‎12/‎2020
OS build 19042.662
Experience Windows Feature Experience Pack 120.2212.551.0
and try again, the only problem is that it uploads an update KB4586876 this update prevent all sorts of things working including File Explorer and also prevented the upload from the CD/DVD drive.
If you are having problems it may be worth checking if you have this update and deleting it. Don't make old people mad.
Richard
Post #870875 2nd Dec 2020 11:44am
Page 2 of 2 <12
