Home > Puma (Tdci) > Side steps query |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
Can’t make any comment on the part or P/N if applicable.
But if you don’t have any luck, just get some neoprene rubber or similar material of appropriate size and thickness and cut to size if needed. Loads of options on eBay from foams, to rubbers of various sizes and thicknesses. This is what I would consider anyway if there wasn’t a part by LR or Manufacturer. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 Last edited by custom90 on 17th Oct 2020 12:10am. Edited 1 time in total |
16th Oct 2020 8:56pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
Thanks. The part is moulded to fit so would prefer to try and find the part. But if all else fails I will have to fabricate something 2015 90 XS Santorini Black
16th Oct 2020 11:45pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3188 |
I tried the same search in the past.. no results.
Perhaps your best bet would be to find a set that has corroded beyond repair / usefulness and take the plastic trim off them. Hopefully they would be cheap enough. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
17th Oct 2020 7:41am |
Yep. Good plan. May have to go down that road. 👍 2015 90 XS Santorini Black
17th Oct 2020 8:28am |
Other option would be to mold in fiberglass... but too labour intensive, as you would need to make a mold first from the good one. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Oct 2020 7:14pm |
