Home > Td5 > Black smoke dodgy MAF or keep looking..... :)
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi All
Would this level of black smoke be caused by a failing MAF or should I keep looking?
MAF is reading low ie 38-40 at idle and 130-140 at 2000rpm so I've just ordered a new VDO/Siemens one which will be here mid next week all being well, but will it cure this or do I need to look elsewhere?
I still have the stock intercooler and CAT etc etc at the mo and as far as I know its not been mapped etc its just passed 108k miles
https://photos.app.goo.gl/emx3YZN5vozfi3CC8
Ben
Post #861955 16th Oct 2020 6:28pm
benspray
ps I did fit a IRB EGR blank the other week as I thought it may be caused by the EGR valve initially...
Post #861956 16th Oct 2020 6:31pm
benspray
Had 3 or 4 litres of diesel purge left thats just gone in with half a tank of fuel just in case it helps Wink
Post #861965 16th Oct 2020 6:57pm
lightning
Disconnect the MAF unit and see how it runs without it connected.
lf it's better then it's likely the MAF unit is the culprit.
Post #862004 16th Oct 2020 9:40pm
dorsetsmith
MAF is reading low ie 38-40 at idle this reading low
MAF is reading idle 55 kgh ------------ 1.95 to 2.01 volts reading from new unit
also check air filter
Post #862037 17th Oct 2020 7:34am
benspray
Cheers will give it a go tomorrow, new air filter will be here Monday - one in there isnt too bad though but just giving everything a going over, only had it 6 weeks still sorting all the small issues Wink
Post #862147 17th Oct 2020 7:20pm
Dinnu
I see you pushed the throttle quite hard twice. The second time you held the throttle a bit longer, and the exhaust cleared before you let off the throttle. Does it smoke if you push the throttle ‘slower’ but still gets high rpm? If no, I would say normal behavior.
Make sure you are not clearing sooth from the exhaust, especially if it was driven lightly. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #862151 17th Oct 2020 7:44pm
benspray
not sure, I'll have to have a try Smile
I don't think it had done anything more than local running about for the past year or so, it was breathing quite heavily when I got it, that has now stopped after a few good runs so some of it could be down to short runs etc I guess Wink
I think theres a boost leak somewhere as well (you can hear the squeal) not sure whether its a hose or manifold at this stage but will all be checked over the next few weeks Smile Likely to get new boost hoses/intercooler and exhaust soon anyway.
Post #862157 17th Oct 2020 8:11pm
Lionel
Australia
You should check the possible boost leak. Such a leak would influence the fuel/air ratio, so that under hard acceleration the fuel supplied by the injectors would be greater than the air required so that unburnt fuel in the form of black smoke would be more than normal in the exhaust.
That said, the MAF readings are low, as pointed out by other posters.
Cheers,
Lionel
Post #862180 18th Oct 2020 3:29am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Low MAF reading should not give you too much diesel.
I would:
Check the air filter
disconnect the MAf
check for air leaks between the turbo and inlet manifold.
Is your turbo still working properly? Good power above 200o rpm? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #862253 18th Oct 2020 1:47pm
benspray
Quick update new MAF fitted today, perfect 58-60 reading at idle, drives better and the smoke has cleared up Smile just a puff when it comes on boost then pulls clean.
Cheers all
Post #862805 21st Oct 2020 1:08pm
