![]() | Home > Td5 > Rear body floor removal |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
I think they might be called 'huck bolts' - a type of rivet, but much stronger and more structural than a 'pop rivet'. If you google them you'll get an idea what you're dealing with.
I think your only option will be to grind them out carefully and then tidy up the remnants once the floor has been lifted. When I did mine, I had the same issues. I did consider how to replace them during the rebuild, but in the end just went with 'pop rivets'. At the end of the day, the fixing itself might be stronger, but the surrounding aluminium itself is exactly the same. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Huck bolts are a steel head and shank that is pushed through a hole from the head side. A collar is then shoved into the shank and a tool is used in a similar way to a pop rivet, but instead of the steel section of a pop rivet expanding the rivet before the stem breaks, with these the stem is used by the tool to grip and as it is tightened the tool is pulled toward the head and it crushes the collar on to the stem and it grips. Then the stem breaks and it leaves what you have. The easiest way to remove is if you can get to the aluminium collar. They are not super strong and you can cut them with a chisel or if you have a super strong grip, very sharp pincers.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic70508.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Just a couple of points. The steel section of a Huck bolt is obviously much stronger than the head of an aluminium pop rivet.byou can obviously get steel pop rivets that are better.
If you could, I would replace these with steel screws and nylock nuts (socket dome heads). After all, you are taking these out for a reason and who is to say that there won't be another reason in the near future. But I am not one for making things look original if I think the alternative is an improvement. Good luck with the work, I hope it goes well for you. |
