Home > Td5 > How many wires go into a rear door ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, I have a few issues with non working items on y rear door, it appears it’s down to broken wires where it goes through the door to body,
So before I strip it out I was wondering how many wires I may find ?
It’s a 51 plate TD5 CSW with heated rear window and rear wiper, but no central locking
I was hoping to use trailer cable or similar to replace the section from inside the car through the rubber tube hobby and into the rear door bits
Thanks in advance
Post #861041 11th Oct 2020 9:00pm
Do you have a high level brake light? If so and with no central locking, it should be five as follows:
Heated screen - white/black
Brake light - green/purple
Motor switched earth - black/green
Motor ignition live - white/green
Earth - black Darren
Post #861052 11th Oct 2020 9:29pm
Procta
You can just buy a plug in play loom for it Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #861069 12th Oct 2020 6:09am
Martin
Site Admin
Has it got the one piece rear door/square buttons around the radio/round fog+ reverse?
If so the above is correct - though if you have central locking there are an extra pair.
Pre 2002 model year (older style door/dash) wiring as follows:
Heated window
12V ignition
Wiper motor
Park switch output
Ground
Brake light (Maybe)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #861071 12th Oct 2020 7:18am
Daisy90
Really ?
I did have a looky around for a ready to go loom but couldn’t see one meself ?
Mines a 51 plate vehicle with the normal radio / at an angle nestled in the older style dash
And yes it has a high level brake light ,
Post #861073 12th Oct 2020 8:01am
