Home > Puma (Tdci) > 3rd row seat bolts |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
Just used a magical bolt remover to free 2 stuck bolts holding the 3rd row seats in place.
Now i need to buy some replacement bolts - preferably not torx. And the nuts for the daft bit that sticks through the floor. Does anyone know the correct size? Any reason I should use torx? Is stainless steel suitable? Thanks. |
11th Oct 2020 12:56pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1761 |
I would avoid stainless bolts due to galvanic reaction and I expect they need to be high tensile bolts for seat mountings. I would go for quality galvanised High tensile bolts and nuts and smear with a good quality grease such as Morris K48 to protect from water , salts etc and avoid galvanic reaction . you can get in tubs cheaply.
See write up by gwyn Lewis https://gwynlewis4x4.co.uk/product/morris-...artridges/ on K48, I’ve found it a very good grease. |
11th Oct 2020 1:21pm |
