Home > General & Technical (L663) > Wireless phone charger pad
Buz1500
I bought my P300 SE from stock and it didn’t come with the optional wireless charging pad. Has anyone had one installed post-purchase?
I’ve spoken to Rob at Duckworths and although the item isn’t listed in the accessories catalogue it is available as a part. The only issue appears to be that it doesn’t come with any wiring. It could well be that the car is already pre-wired but without pulling the centre console apart I don’t know.
Post #860223 7th Oct 2020 9:45am
Tim in Scotland
Anyone with access to a workshop manual?
My car didn’t have one either but I bought this from my local Apple franchise store and I can move it from the house to the car as I like, it isn’t an elegant solution but it works for a fraction of the cost of the LR part. I plug it into the USB socket for the back seats leading the cable down between the seat and the cubby box. I rarely use Apple car Play but this way I can plug a white cable into the front USB to connect - I don’t know which method has priority for charging though, white cable to USB or Induction charger. It was when a family member had their induction charger plugged into the back and forgot to take it away after I dropped them off that I thought I would try it in the front. The phone does get quite warm regardless of whether it’s on the pad without connection to Apple Car Play or if it is connected to the front socket.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #860264 7th Oct 2020 12:54pm
jst
I have similar mounted on dash in mine for android, albeit an early defender Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860265 7th Oct 2020 12:58pm
J77
I think I would just plug my phone in.
Post #860275 7th Oct 2020 2:13pm
Tim in Scotland
Which is what I do for 90% of the time as I forget to take the induction pad out to the car! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #860276 7th Oct 2020 2:37pm
J77
If the new Defender was able to do wireless CarPlay it might be worth having the wireless charging.
Post #860277 7th Oct 2020 2:47pm
jst
i dont like cables cluttering the dash so wireless pad works for me Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860282 7th Oct 2020 3:07pm
Philm
I bought one of these.
https://www.ebay.co.uk/itm/Non-Slip-Car-QI...Swbe1fdt6I
Plugged into one of the rear USB ports and sits in the same place as the LR fitted one.
Works perfectly. Thumbs Up
Post #860285 7th Oct 2020 3:31pm
Q86ARR
I don't think this is a retrofit option
It's more integrated than the previous wireless charger. This also has phone signal booster and is integrated in to the Pivi system for the charging icons
Without stripping out the console you wouldn't know if it was prewired. I doubt it will be after the introduction of KSK harnesses a few years a go now
Post #860776 10th Oct 2020 8:10am
