Home > Puma (Tdci) > 2.4 90CSW known 'design flaws'? |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Axle reinforcement issue:-
https://www.defender2.net/forum/topic60413-540.html As a starter for (another) 10.. Rgds. Chris |
6th Oct 2020 11:44pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3019 |
A couple of cheap fixes:
Headlight loom (Boomslang, Landreiziger etc.) to protect switch from melting. X Trouser door strikers to stop ripping belt loops. WARNING. This post may contain sarcasm. |
7th Oct 2020 12:04am |
Spare wheel carrier. Rgds.
Chris |
7th Oct 2020 12:10am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Remap.... Shut off egr valve.
7th Oct 2020 4:25am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
front diff is 2 gear type can cause catastrophic loss of control if gives up the ghost unexpectedly,
some prop shafts have difficult to reach or no grease nipples leading to lack of servicing and premature wear front drive flange splines ungreased leading to wear some vehicles had a recall for seat belt mounts DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
7th Oct 2020 6:24am |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Just a warning on Dixon Fabrication. They are very good with metal work but poor at painting. The front bumper I purchased from them lasted all of 3 months before paint started peeling and rust appeared.
I'd perhaps ask if you can buy the product bare (at a slight discount) and do the coating in a product of your choice. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
7th Oct 2020 7:59am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1351 |
A few more,
Corrosion of windscreen frame due to poor painting at the factory. Corrosion of windscreen to bulkhead blocks, again due to poor painting at the factory. Inadequate windscreen washer system. One for 110 owners, rear wings tearing at mud flap mounting points. Thinner material used in later body, with no reinforcements to compensate. This is quickly becoming "101 things you should know before buying a Puma Defender" |
7th Oct 2020 6:35pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1205 |
101 things will not be enough..... but I still love them all!! 2010 XS USW
1957 Series One 88 diesel 1958 Series One 88 4x2 |
7th Oct 2020 6:40pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1191 |
With regards to point 7
Don’t overkill bumper strength. You want the bumper to give and bend. If it doesn’t you will transfer the damage to the chassis leg.... Don’t ask me how I know Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion Honda Benly CD200....Maroon ------------- Chausson 98.........7.5m of fun |
7th Oct 2020 8:31pm |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 176 |
A few others that I experienced:
- Heater Matrix: when using the heater in winter, mine is blowing much warmer air on the left side than on the right side. To the point that on very cold days there are 2 choices, either I'm cooking and the passenger is ok, or I'm ok and the passenger is freezing. If you have this issue, you may want to search for service bulletin SSM39653 and apply the JLR fix if you happen to drop the dash for some reason and have access to the infamous heater matrix. - Fuel tank filler hose: mine perished and cracked, spilling fuel after filling up and driving around corners. Just check the state of yours before it gets bad by visual inspection under the wheel arch. As mine is a 110 I got rid of this part and used it as an excuse to install a long range tank in the rear right arch. - Security : you said you had it done, good. Have you checked that you do have the volumetric sensor installed above the B post (UK driver side)? If not you can retrofit one easily as the wiring loom and connector should normally be there waiting under the headliner. I did that using an old sensor from ebay. - Turbo/intercooler/inlet manifold hoses : depending on how nicely it was installed and routed at factory in yours, it may be rubbing against bolts or other components in the engine bay, and one day or the other you'll get a hole or cut that will force the car in limp mode. Check your hoses and replace with new proactively if needed. /Mat |
8th Oct 2020 12:11pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Thanks guys - this is a superb list. I'll factor in each point as I'm running through the snags and maintenance jobs on the 90.
13th Oct 2020 6:50pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1761 |
If going for a front bumper. Look at uproar 4x4. Superb bumpers, not cheap, but really good . And for belt and braces wax coat rear and underside of the bumper.
Oh and if you want to see in the dark. JW Speaker headlights |
13th Oct 2020 7:47pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Nakatanenga fan spacer and a thermostat that opens at 82 degrees and not the 88 that it comes with.
Otherwise you will struggle in hot countries/temperatures. I have only put on mine the spacer and it is better but the thermostat is also important. Fabio |
14th Oct 2020 6:06am |
