![]() | Home > Puma (Tdci) > Nanocom Help |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
The latest doc I can find is this https://nanocom-diagnostics.com/downloads/...-evolution
So if your alarm module is at a pre 2014 puma or a TD5 spec then the nanocom will be ok to program a fob on the Lucas 10AS alarm module. Apparently the green cased ones are ok and the black cased ones are not supported. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1662 ![]() ![]() |
hawkeye and nanaocom can do some of the the bits you need.easy to do and a few guides on ine just make a note of any settings before you change them in case you have to go back.
fob teaching is easy just make sure they work before you try and code them a good independent like gemm4x4 can do more perhaps and easier. hawkeyes can do more lr (full spec on bearmach page) than nanocm where you need to buy a code for every vehicle you want to work on |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Nanocom Evolution does now support the black ALM: https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu
That’s handy to know Martin. My 2.2 is a 10AS module but handy to know my nanocom supports the later ALM modules if I need to help out another local member.
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Oh Blimey, I can see this going horribly wrong, me and anything technical generally ends up in disaster
![]() Thanks for the replies gents. Anybody in Edinburgh area that has the required equipment and the technical know how? |
