Home > For Sale & Wanted > [For Sale] Garage Clear out
Morepower
New Zealand
As I've now just sold my last Defender I have various bits left over, So in no Particular order.... I'm listing them here, I can PM pictures if required (Once I'm home Monday from work)
2016 90XS ECU £125
2013 110XS ECU £100
2013 Cat Back Exhaust System (STD) £50... USED
110 Bowler rear springs USED £50 the pair
110 Rear Mud Guard brackets and mounts £15 the pair
TDCI Gearstick (left over from my Bowler conversion) some marks from memory £20
Bowler TDCI Clutch center ceramic uprated (Has been fitted, But basically new... Bought from Bowler on a trip down... I believe they bedded them in ready to go) £35
2013 Rear wheel carrier inc washers £30
Various other bits and pieces, TDCI turbo hoses (basically new as fitted Samco from day one) Complete "set" inc airbox to turbo £30
BAS Remote Map Tool (also does diagnostics) has two Defenders already loaded 150 & 170 maps... Not sure if this can be used on another vehicle (but you may be able to use it with the above ecu's as they are the originals that where cloned so if the ecu was fitted then the box should be able to send the maps to them)... BEST SPEAK WITH BAS ABOUT THIS £150
Genuine LR Defender wing Mirror Assembly (Think it's drivers side, Will Check) £25... Also have the passengers, but stripped down into parts..
Just found a new TDCI oil filter cartridge (Genuine LR)
Bumper end caps
All items plus postage
Regards
Tim[/b] It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #856775 19th Sep 2020 1:42am
Matt110
Could we have done on the BAS remote remap tool. I'll give Pete a call on Monday to see what he says is ok to do. Thumbs Up
Post #856788 19th Sep 2020 7:50am
Matt110
Dibbs.... Rather than *done. Sorry am on mobile not sure how to edit.
Post #856790 19th Sep 2020 7:58am
Jon w
Wales 1991 Defender 90 200 Tdi HT Epsom Green
Is the exhaust from a 90 or 110? If a 90 please can I have a picture and cost posted
Thanks
Post #857130 20th Sep 2020 9:47pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Could I have second dibbs if Matt110 doesn’t want the BAS remap tool 15 plate 2.2SW XS
Post #857260 21st Sep 2020 7:37pm
Morepower
New Zealand
Exhaust is from a 110...Jon It doesn't matter how bad it is, It can always get worse...
Post #857365 22nd Sep 2020 8:23am
Matt110
Quick bit of feedback to say I've just dropped Pete an email to ask his advice and check what is OK with him. Will share with morepower so he can update when the feedback is back.
Post #857375 22nd Sep 2020 10:10am
Matt110
Feedback provided to morepower, i'll let him update his ad as he wishes, but I said I have removed dibbs on the tool as it doesn't fit with what I can do with my current purchases from Pete.
Trying desperately not to upset any apple carts etc!! Thumbs Up Thumbs Up
Post #857379 22nd Sep 2020 10:40am
Matt
I’m not sure the BAS tool is going to work for me either so my second dibbs is also removed 15 plate 2.2SW XS
Post #857545 23rd Sep 2020 7:01am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Will take the bowler rear springs, do you know whether they're standard height or lowered?
Thanks,
Alexander 110 Tdci Double Cab
Post #857845 24th Sep 2020 11:38am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
PM sent regarding the hoses 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #857896 24th Sep 2020 4:36pm
