Home > Technical > engine bay/bonnet soundproofing
jst
After some advice please. I have some self adhesive nice soundnproofongnleft over. Is it worth adding it to the underside of bonnet to reduce vehicle noise for when you are in the vehicle traveling or are the noise benefits negligible?
Does it just unstick and fall down or reduce heat disappation disappation? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856742 18th Sep 2020 9:50pm
I think that soundproofing a Puma bonnet is less worthwhile than earlier ones. It's much stiffer and doesn't resonate in the same way, which is what mass sound deadening materials are good at reducing. You can probably reduce transmitted sound externally with the right materials but for inside the cabin, treating the inside of the bulkhead will give much more benefit. Darren
Post #856810 19th Sep 2020 9:13am
just wrote:
... soundnproofongnleft ...
Germany would be proud of that word! Gotta love smartphones! Rolling with laughter
Post #856827 19th Sep 2020 9:48am
grafty99
Bow down Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #856830 19th Sep 2020 9:54am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Frighteningly I read the original post without even registering it contained an example of Teutonic computerspeak Confused
Post #856838 19th Sep 2020 10:13am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
I’m not sure soundproofing the bonnet will help, but when you open the vents the sound of the engine increases dramatically when stationary.
So it’s worth a try. 2002 td5 90 county hardtop
Post #856841 19th Sep 2020 10:17am
Mo Murphy
Back to James question, does the self-adhesive anti drum stay stuck to the bonnet or does it pull itself off when it gets hot ?
50 Shades of Pennine Grey
Post #856852 19th Sep 2020 11:04am
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
i have done mine with silent coat and foam there is not a huge improvement in normal driving but a huge improvement with the vents open you can barely hear the engine, it was done a year (8k miles) or so ago and has not come loose nobody is perfect but being Scottish is a start
Post #856859 19th Sep 2020 11:33am
Mo Murphy
Excellent news T140. I have an early bonnet and you can see as well as hear it drum.
Post #856868 19th Sep 2020 12:05pm
macfrank
Thumbs Up why waste a whole sentence when one word does it
Laughing
Post #856913 19th Sep 2020 4:31pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
A year ago I added some Dynamat Hoodliner to mine, it is still in place, no problem.
If you want it to stick in place for a while, there a 2 rules:
- Degrease, and degrease again before applying !
- Do not go wading bonnet deep or it may soak water and come loose with increased weight
Also, as it is about 2cm thick, I had to trim it in some areas to avoid it getting in contact with the engine.
Regarding noise benefit: it is not worse! and when it comes to soundproofing, I believe every little bit counts. So after too many days/nights spent on soundproofing the interior I just thought I could take 1 hour to treat the bonnet.
In my case, it was changing the bonnet hinges that actually suppressed the bonnet vibrations towards the cabin and made a very welcome improvement. I used the Nakatanenga ones with PU bushes, thus avoiding any metal to metal contact. https://www.nakatanenga.de/en/optional-equ...anti-theft
/Mat
Post #857099 20th Sep 2020 6:51pm
jst
Great, thank you everyone for comments. Doesn't seem to make that much of a difference then by the sounds of it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #857101 20th Sep 2020 7:07pm
Hufflepuff
Had it put on mine (td5), and I can't tell any difference, which in fairness the fitter did indicate would be the case.
It should protect the bonnet paint from a bit of engine heat though, if that is a concern to you? 2005 Td5 90 XS
1989 V8 110 CSW
Post #857501 22nd Sep 2020 9:01pm
