Home > Maintenance & Modifications > Fitting side steps - riv nut query!
Packster82
2013 Defender 110 Puma 2.2 CSW Keswick Green
Hi guys, I’m fitting some drop down side steps to a 110 puma. I’ve attached them to the inside of the sill but am unsure on connecting the supporting crossbar to the chassis. The instructions say to drill an 9.5 mm hole in the chassis for the Rivnut, however where the hole is likely to be drilled there is a hexagonal hole, am I to assume this is a predrilled hole for precisely fitting a step like I’m doing? And does it need a hexagonal rivnut? Also the hole also seems marginally bigger than 8mm, more like 10 mm. Any clarification would be appreciated! 3 photos of the hole attached. Cheers. Alex
Post #856498 17th Sep 2020 3:15pm
You need this sort of thing:
https://www.part-on.co.uk/product/m6-flat-...nut-100pk/
https://www.fastenright.com/general-fixing...n-end/rn06
These links are chosen at random as examples, do not assume that these are the right size.
Post #856512 17th Sep 2020 4:17pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Here you go. It’s item 10.
(I’m on with the same job on my 110).
Post #856517 17th Sep 2020 4:33pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
As above, but it should be in the kit?
A tip if you use the vehicle off road is to flip the support bar around end to end and fit it upside down so that it is a couple of inches higher along its length. It makes it less likely to hang up off road and bend the steps back. Doesn't quite look right but looks better than it does after you smite it on a rock! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #856836 19th Sep 2020 10:10am
Packster82
Thanks guys, the kit I bought was from Bearmach and included round rivnuts so looks like I’ll need to get hold of some hexagonal ones then should be job done. Thanks for the tip Bogmonster, I did think you lost quite a bit of ground clearance installing as per the instructions.
Post #856846 19th Sep 2020 10:34am
