|  | Home > Td5 > Brakes, steering wheel and grey smoke from engine!! |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2309      | Sounds more likley the engine stopped first, at thie point you will loose any brake servo assistance and also power steering  hence the issues you mention...... | ||
|  13th Sep 2020 7:38pm |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039      | Or your engine died or there was something wrong with the ancillary belt so your Alternator and Steering pump stopped working.
 This could be one off the pulley bearing that block or one off the Ancillaries. The burning smell can come from the belt. But I think if you open the bonnet you will easily see that. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) | ||
|  13th Sep 2020 8:54pm |
| LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13  | Ok, I was worried it was the new brake calipers siezing which they shouldnt have done being new. Thanks. | ||
|  13th Sep 2020 8:57pm |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804      | I would say something has siezed causing the belt to slip (burning smell) and therefore stop turning the power steering pump (heavy steering) and altenator (loss of vaccum pump and so no servo assistance).
 Were there any warning lights on the dash when this happened? If battery charge light only then its likely to be belt related. If oil light came on as well then the engine might have stopped. 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton | ||
|  14th Sep 2020 7:22am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
