Home > Td5 > Td5 Relays
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
Td5 Relays
Just a quick question regarding relays. My 2004 TD5 is not turning over properly and I think it is the relays; would be very grateful if anyone can confirm what exactly I need to buy to replace the following:
Fuel pump relay [20A?];
Main relay [30A?];
Glow plug relay [30A?].
Any recommendations for where to buy appreciated.
Post #855879 13th Sep 2020 8:20pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
What do you mean with not turning over properly? Is your startermotor turning but not as quick as you would expect?
That could be battery voltage while cranking or the grease in the gearbox of your startermotor is almost solid.
A relay works in my eyes or doesn't work. If the contacts are bad and a high current will go through they will get hot. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #855893 13th Sep 2020 9:46pm
cee-b
Yep, I'm with Roel; a relay generally works or it doesn't.
What are your symptoms? - and what led you to suspect the relays? which all do very different jobs, none of them related to an engine that is turning over, but not turning over properly.
Post #857682 23rd Sep 2020 6:49pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Re: Td5 Relays
Main relay [30A?];
If your starter is not turning normally, the solenoid is the normal culprit.
More information would be helpful.
Post #857714 23rd Sep 2020 7:52pm
