Home > Td5 > Ignition switch live feed in the rear?
excossack
Is there an ignition switched live feed in the rear of a 110? I know there is the purple wire for permanent live feed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #855733 12th Sep 2020 9:02pm
Not as standard, no. If you've got towing electrics then there will be one as part of that loom that you could tap into but nothing as convenient as the purple wire for a permanent feed. Darren
Post #855738 12th Sep 2020 9:24pm
excossack
Cheers. I have standard towing electrics. 7 pin. Shame, means i need to run a new power feed for the camera. Not wanting to use the reverse light as i plan on flicking to camera while driving or towing cars on the trailer. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855741 12th Sep 2020 9:35pm
Martin
Site Admin
Ignition feed (white/green) present on plug for the rear door (for rear wiper).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855744 12th Sep 2020 9:52pm
PaulMc
Post 2002, there's a white/green ignition-switched live to the rear wiper motor.
This can be accessed at the 6-way sealed connectors between the chassis harness and the rear door harness. Paul.
Post #855746 12th Sep 2020 9:56pm
Martin
Site Admin
Pre-2002MY (old style door) it's there as well. On the 4 pin plug (3 used), the feed to the park switch for auto-parking.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855749 12th Sep 2020 10:31pm
Ah, forgot about the wiper motor! Sorry! Darren
Post #855750 12th Sep 2020 10:32pm
excossack
Thanks chaps. I hadnt considered the rear wiper as an option 1999 Defender TD5 110
Regards
John M0VAZ
Post #855768 13th Sep 2020 7:55am
excossack
Found the wire. Its green by the time it gets to the wiper motor. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855842 13th Sep 2020 5:30pm
