Home > Wheels & Tyres > Tyre
Bonnievale
South Africa 1994 Defender 110 200 Tdi CSW Alaska White
Tyre
On my Defender 110: Terra 265/75 R16
If I change the full set, what other size you recommended?
Post #853381 31st Aug 2020 5:32pm
255/85/R16. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #853384 31st Aug 2020 5:50pm
Ianh
Post #853391 31st Aug 2020 6:05pm
miker
That depends what it is you don't like about the current size!
Post #853485 31st Aug 2020 11:40pm
Bonnievale
It is not that I don't like it, but all the fundi's tell me that 225/85 R16 is the more logical choice.
Post #853501 1st Sep 2020 7:22am
VVS210
235/85R16 is the 'standard' size for your 110 & probably easiest to find locally for you.
Depends on the terrain you drive on but 265/75R16 is the same rolling circumference but will give the tyre a larger footprint for driving on soft ground or sand etc.
If you find that the size you have works for you then stick with it.
Post #853504 1st Sep 2020 7:28am
Ianh
A few of the most used options
235/85/16 = diameter 31.7 inch, width 9.3 inch
265/75/16 = diameter 31.6 inch, width 10.4 inch
285/75/16 = diameter 32.8 inch, width 11.2 inch
255/85/16 = diameter 33.1 inch width 10 inch
https://tiresize.com/comparison/ allows you to compare two tyre options at a time
Post #853640 1st Sep 2020 5:50pm
Dave S
Northern Ireland 2012 Defender 110 Puma 2.2 XS CSW Orkney Grey
Definitely 255 85 16. Works on so many levels.
Post #856433 17th Sep 2020 9:03am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
^^^ This is the business! ^^^ Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #856436 17th Sep 2020 9:27am
Dave S
Many thanks for that.
Post #856646 18th Sep 2020 12:08pm
