![]() | Home > Maintenance & Modifications > Rear ARB kit |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5983 ![]() ![]() |
Not sure which bit it hitting as it’s not something I’ve encountered. But you can space your ARB down at the mounting points using tow bar spacers as they are the correct hole spacing.
This sort of thing.
https://www.towsure.com/towball-spacer-block-25mm-1 |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
Thanks I will have a nosey and try and load a good picture to demonstrate. Will look into the spacer idea. 1990 200tdi conversion 90
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2364 ![]() ![]() ![]() |
Is the exhaust standard Harry ? Or cobbled together with bits of others ?
I think the mid to read section is standard, only modified at the engine outlet down pipe. 1990 200tdi conversion 90
![]() I think this is it. 1990 200tdi conversion 90 |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 675 ![]() ![]() ![]() |
You are trying to fit an ARB onto a chassis / exhaust combination that was never designed to accept an ARB, that’s why it fouls.
Ta, I follow a 89 Defender chippy on Insta. I noticed he has a rear ARB fitted hence my curiosity resurrection. Ah well one less job to do the. 👍. 1990 200tdi conversion 90
