Home > Maintenance & Modifications > Which rattle can?
discomog
Which rattle can?
I've just purchased and fitted a pair of front and a pair of rear mudflap brackets in polished stainless from Bison. Pleased with the quality (same thickness as originals 2mm). I'm pleased with the fronts but I think the rears would look better in satin black to match the cross member. I don't want to get the spray gun out as it will take four times as long to clean it out as it will to spray the brackets, so can anyone recommend an etch primer in a rattle can?
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #849950 14th Aug 2020 3:42pm
Ianh
I’ve used U-pol acid 8 on aluminium, and expect it would be ok on stainless steel, although it does not say for use on stainless.
https://www.u-pol.com/uk/en-uk/product/pre...zaqz8rTWf0
I use arc rite for their corroless chassis paints but they also do an acid etch that they state covers stainless as well as aluminium and galvanised steel https://www.arc-rite.co.uk/aluminium-stain...zontalTab1
Post #849957 14th Aug 2020 4:30pm
nitram17
Re: Which rattle can?
Try Bilts primer........ https://www.bilthamber.com/paints-and-coatings/etchweld ps good job on your crossmember btw!
Post #849966 14th Aug 2020 5:01pm
mk1collector
Upol acid as above. You can usually get it Halfords too. Ray
My build thread
Post #849976 14th Aug 2020 6:00pm
discomog
Thanks for suggestions - I shall give U-Pol No.8 a try. Defender 90XS SW
Morgan Plus 8
Post #850059 15th Aug 2020 8:29am
gcc130
+1 for U-pol
Post #850078 15th Aug 2020 10:02am
