Home > Off Topic > Deutz Fahr experts?
excossack
Deutz Fahr experts?
Do we have any Deutz Fahr experts on here?
A mate replaced a seal on the gear selector on a dx3.90 I think it is and after doing so now is unable to select gears properly. From what I recall, the gear shaft will pull out a bit and and whats to spring back in place.
He can twirst it and lock it in place.
At one point he could not start it until shorting the switch but now he is at the point where he only has one gear....Almost like the gear selector needs aligning? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #848641 8th Aug 2020 9:44am
lohr500
Don't know anything about the Deutz dx3.90 and assuming it has a conventional manual gearbox, if the gears worked before he replaced the seal, then I am guessing it is going to be something simple like the end of the gear selector rod not being correctly located in the selector shafts inside the box.
My bid would be to remove the plate where he replaced the seal and look at the selector slide positions. Then make sure when the cover plate is offered back up to the gearbox, the end of the gear selector rod is located correctly in the sliders. Without knowing the set up, it may be better to select neutral by carefully moving the gear selector sliders as he may have got the selectors out of alignment by moving the shift lever when it was not properly located.
Post #848654 8th Aug 2020 11:10am
discomog
This may be worth a longshot if no one on hear can help:-
https://www.justanswer.co.uk/sip/deutz-fahr?r=ppc|ga|5|1621210534|70310861424|&JPKW=deutz-fahr%20problem&JPDC=S&JPST=&JPAD=318196700791&JPMT=b&JPNW=g&JPAF=txt&JPRC=1&JPCD=20181104&JPOP=&JCLT=&cmpid=1621210534&agid=70310861424&fiid=&tgtid=kwd-5983776652&ntw=g&dvc=c&gclid=EAIaIQobChMIpI27xsOL6wIVD-vtCh10OQ3VEAMYASAAEgLyNfD_BwE Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #848666 8th Aug 2020 12:46pm
excossack
Thanks for the replies people. I will pass on the suggestions. 1999 Defender TD5 110
Regards
John M0VAZ
Post #848701 8th Aug 2020 7:37pm
