![]() | Home > Technical > Lights help needed |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
I fitted Ring Aurora DRL lights to two 2.4 Pumas and they work great and very easy to wire up. I decided to fit them to a 200 tdi and a 300 tdi but they do not work on the tdi Defenders. They light up on ignition then go out. Wired the very same as the Puma, two wires to the battery and one to the side light as per instructions.
The unit that does not work in the tdi (the 300 and the 200), I wired it up to the Puma and it works as intended. I know modern cars (Puma) charge slightly higher than older cars (tdi) but I did not think that would make a difference to DRL lights. Anyway any ideas on whether I can get the DRL lights to work on the tdi? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
You may need to wire it through a relay on the Tdi's rather than using the Ring control box. Simple enough to do, just need a normally closed relay.
Wire the relay coil to ground and side lights. The switched terminals to ignition and DRL positive. When the ignition is active the DRLs will light. When you turn on the side lights, it will power the relay coil and open the ignition feed circuit to the DRLs and extinguish them - as per law 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thank you. That is how the work on the Puma. The 300 tdi is due to go in to get some work done so I might get them to do the wiring alteration you suggest. Many thanks
| All times are GMT |
