![]() | Home > Maintenance & Modifications > Drop down table “Springtail” |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
Nice! where did you get it? Puma 110" SW
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Do a eBay search for
Springtail for Jeep JL Folding MOLLE Table Tailgate Rear Door No Drill USAMADE ![]() |
Darcy Fairfax Member Since: 06 Oct 2014 Location: London Posts: 721 ![]() ![]() ![]() |
Like that
To fit it to a defender, you have to drill it.... you need to buy extended bolts off the wheel carrier, 100mm, and then drill the door card.... Someone put a front runner table on a defender, if you do a search, you can find the extra nuts and bolts you need.
Depending on how many bump outs you have on the rear door, you might need to add bolts extenders, but it’s really basic stuff. I made a template of the bolt pattern and then just drilled the table... and bolted it down, took an hour. |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
Very nice but bit expensive
Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71 ![]() ![]() ![]() |
This is my effort
![]() Click image to enlarge Finest chinesium, 60 quid, suplemented with the MUD molle rack and bags ![]() |
