![]() | Home > Off Topic > North Norfolk assistance needed please! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6709 ![]() ![]() ![]() |
Hi all,
I’m in need of some Information/advice/assistance in North Norfolk. I’m away on holiday in the D3 and the brake line at the back has developed a leak. I’m near Walsingham - has anyone got a recommendation of who is worth a try to see if they can fit it in ASAP? Thanks all for any help. ![]() ![]() |
London 52 Member Since: 21 Oct 2014 Location: Lincoln Posts: 312 ![]() ![]() ![]() |
Hi Martin,
This guy might be worth a try: Richard at Glencoyne Engineering Unit 10, Heath Road Industrial Estate, Banham, Norfolk NR16 2HS 1 h 5 min (39.9 mi) via A1065 or 1 h 7 min (46.1 mi) via A1067 from Little Walsingham Telephone number 01953 888731 Hope you get sorted Don |
Thanks I've got it booked in a place in Sheringham in the morning so let's see
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3648 ![]() ![]() ![]() |
I have never used Hayward Revive, but I have seen their work and it is very good and they are in the right direction for you. Banham is a bit out of your way from North Norfolk, although I have heard good reports about Glencoyne. I think he is more of a Series kind of a garage.
Hopefully a standard non-specialist garage should be able to sort a brake pipe problem out. I can recommend A&M Motors in Lenwade (Great Witchingham) which is a bit in land from the coast. They have a very modern set up there and Alistair is good bloke ![]() There's a dinosaur park near by to look round, if that's your kind of thing? No, not mine either (they haven't got any real dinosaurs... ![]() Hope you get the Disco sorted and enjoy your time in lovely Norfolk, Martin ![]() |
