Home > Maintenance & Modifications > Rubber lining for DC bed
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Any ideas/suggestions for the above chaps? I'm about to pick up my new DC in the next day or 2 and want to line it with something from the off. What do you think to getting some rubber down, so it can be taken out/swept/hosed, etc?
Anyone done it? Also, did you just do the floor, or floor + up & over the wheel 'boxes'?
Searched on eBay, but can't really tell how much I'd need until I get it to measure up....anyone know the rough dimensions I'd need so I can think about ordering some ready?
Mr. Green Mark
2011 110 XS DC
Stornoway Grey
Post #79502 8th Jul 2011 12:24pm
bob neville
I purchased a roll of black industrial rubber chequer plate mat of ebay when I got my DC. The mat is approx 5mm thick and heavy ! I used it to cover just the load area and it works a treat.
I have some spare if you want some but it would be collect only due to the weight !
Bob
Post #79504 8th Jul 2011 12:42pm
MuddyMarky
Thanks for the offer Bob. Do you have any pics of it fitted?
I'm thinking of covering the wheel arch box area, probably fixing it, and making a floor mat that can be removed to clean it easily.......I've found out the length of the bed, but I can't find any other measurements....
The stuff I've seen is 3mm and sold in 1m & 1.2m widths. Think I could do what I want to with 2 metres, or go for 3 to be safe? Mark
2011 110 XS DC
Stornoway Grey
Post #79506 8th Jul 2011 12:45pm
Zagato
Post #79507 8th Jul 2011 12:46pm
bob neville
Bit stuck to get a picture at the moment as my vehicle is in the dealers for warranty work.
If it comes back today I will get some pics for you.
I have probably got at least 2 or 3 metres spare but will check over the weekend.
The roll I have is closer to two metres wide but again I can check for you over the next couple of days.
I also used it under the rear seats - it stops anything I put under there sliding about.
Bob
Post #79508 8th Jul 2011 12:51pm
MuddyMarky
bob neville wrote:
I also used it under the rear seats - it stops anything I put under there sliding about. Bob
Good idea Thumbs Up Have a think how much you'd like for it/some and we'll see what we can do.
Cheers Mark
2011 110 XS DC
Stornoway Grey
Post #79509 8th Jul 2011 12:53pm
bob neville
FOC - all you need to do is collect it.
If my vehicle is back this weekend I can get everything measured up for you.
Bob
Post #79521 8th Jul 2011 1:20pm
All Terrain
United Kingdom 2004 Defender 110 Td5 XS DCPU Java Black
Mark/Bob,
If you don't sort out the collection between you can I have first refusal please?
Cheers,
David
Post #79553 8th Jul 2011 6:22pm
bob neville
David
I might have some left after I have sorted out Mark's requirements - I will let you know Thumbs Up
I got my vehicle back tonight so can do all the measuring over the weekend - before it goes back in again to find out exactly what has fallen apart in the passengers door - might be looking at a new door.
Bob
Post #79565 8th Jul 2011 8:03pm
MuddyMarky
Just pm'd you fella Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #79566 8th Jul 2011 8:09pm
bob neville
Replied Thumbs Up
Bob
Post #79568 8th Jul 2011 8:30pm
I used agricultural cow matting in the back of my 110. it's got ribs in it so you can hose it and the water will all travel in one direction. it's thick... about 15mm... and bluddy heavy! but it deadens the road noise quite well.
Comes in large sheets, think it's 8x4, same as plasterboard. but is flat, so if you want to do the "sides" of the tub you'd have to bolt/glue it in place.
Got mine from the local WMF shop.
Post #79602 9th Jul 2011 10:55am
bob neville
Mark/David
Just done the sizing.
To do the tub and all of the two wheel arches takes 2.2 metres by 1.2 metres, wheel arches take over a metre for both sides Shocked Not 100% sure how you will fit it to the wheel arches ?
I have about 4.7 metres by 1.2 metres, so enough for both of you to do all of the rear tub but not under the rear seats. If I can blag an extra couple of metres from my colleague at work that will sort under the rear seats as well Thumbs Up
Bob
Post #79615 9th Jul 2011 12:56pm
MuddyMarky
Thanks Bob,
for the arches, I might actually use some large width double sided velcro or something. Not too worried about under the rear seat, to save you trying to blag some extra for me.
We'll speak later in the week, but we're OK for Sunday matey Smile Mark
2011 110 XS DC
Stornoway Grey
Post #79656 9th Jul 2011 9:17pm
bob neville
Mark
Velcro will probably be OK as there will not be to much weight on the arch sides.
Speak to you later in the week.
Bob
Post #79658 9th Jul 2011 9:25pm
