Home > Puma (Tdci) > The Two Amigos - ABS Fault - shuttle valve switch failure
Bluest
I've read a lot about the the 3 amigos lights coming on relation to ABS faults. I have an ABS issue, but it is showing only two of the three amigos lights. I have used the Nanocom to read the codes and I have 1 fault code stored in the ABS module: 13-07 shuttle valve switch failure.
Can anyone point me in the right direction for fixing this problem?
 2007 110 TDCi Station Wagon XS
Post #842118 6th Jul 2020 3:47pm
dorsetsmith
shuttle valve switch are part of abs pump modulator right next to brake servo and a job to remover the unit so that switch can be removed
Post #842126 6th Jul 2020 4:39pm
Bluest
Is that a serviceable part? 2007 110 TDCi Station Wagon XS
Post #842131 6th Jul 2020 4:54pm
dorsetsmith
Post #842134 6th Jul 2020 5:09pm
Bluest
Thanks Dorset, good to know it can be rebuilt Thumbs Up Just need to extract it from the car, which looks fun.
Is it likely the fault lies just with the shuttle valve actuator? These seem to be available quite cheaply for D2s and I wondered if it was the same part. 2007 110 TDCi Station Wagon XS
Post #842163 6th Jul 2020 8:06pm
Bluest
Sorry to bump my own thread, but looking for anybody with experience of this fault.
I have seen this repair kit which claims to offer more than just a replacement shuttle valve modulator, but there are no pics of the extra bits. Any thoughts? 2007 110 TDCi Station Wagon XS
Post #842322 7th Jul 2020 2:00pm
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
Its generally the switch that needs replacing unless the innards of the modulator are really corroded.
The switch is fairly cheap to replace (around £30) it's on the bottom of the ABS pump. held in by three bolts. fairly easy to replace. the hard job is getting the pump out.
to get the pump out, you'll need to drain (suck out the fluid from the mastercylinder res - use a big old syringe)
slacken off the pedal box (6x 13mm bolts in the footwell) undo all the unions on the abs pump (4 on top and 2 at the back) tie them out of the way. I undid the clip on the top the pedal box as well as it gave the pipes a bit more moevement.
undo the mounting bush from the bracket at the front of the ABS pump (10mm) . this allows you to lift the front end of the pump and pull it forward so that the rear mounting bushes come out of their cups. then it's free to wiggle around and out of the car. you'll have to push the pedal box over towards the engine so that the pump clears it.
once out, turn the pump over and you'll see 3 little alen bolts holding a black plastic strip on. this is the shuttle valve switch.
Post #842325 7th Jul 2020 2:26pm
Bluest
Thanks Neon. I read it may be easier to just take the wing off rather than wrestle with it.
Anyone know the correct part number for the shuttle valve switch for a 2.4tdci? The web is full of D2 related info, but not much Defender stuff. 2007 110 TDCi Station Wagon XS
Post #842335 7th Jul 2020 2:57pm
neon1991
The wabco unit is the same for both disco II and defender. The shuttle switch is the same. Taking the wing off is a lot more involved. I looked and decided to go my route after looking at everything attached to the wing and inner wing etc
Post #842357 7th Jul 2020 5:08pm
Bluest
Ordered this today, so looking forward to skinnning my knuckles and lacerating my forearms in the coming week.
https://www.lrdirect.com/SWO500030-Repair-..._https=yes
Out of curiosity, this problem is often referred to as causing the 3 amigos, but I only have 2 of the 3 lights showing. Anyone know why that would be? 2007 110 TDCi Station Wagon XS
Post #847227 31st Jul 2020 12:18pm
On earlier models - the Discovery II in particular - ABS faults would habitually light up ABS, TC and brake warning light, hence the three amigos. I guess the name has stuck despite the change in the way that faults now manifest. Darren
Post #847243 31st Jul 2020 2:17pm
Bluest
I’ve done this job today. Fairly easy one I took the wing off. Just a point about removing the pump. It is mounted on three rubber mounts. You only need to undo the front one. You can then lift the front of the pump and the it will pull out of the rear mounts. 2007 110 TDCi Station Wagon XS
Post #852972 29th Aug 2020 7:43pm
Helstoon
United Kingdom 1997 Defender 90 300 Tdi HT Tamar Blue
I had this problem recently where the ABS and TC lights kept coming on intrmittently, don't have a fault code reader so looked for anything obvious, pushed in all relays under drivers seat and the problems has now gone away. It might be worth trying.
Cherry
Paul
Post #853144 30th Aug 2020 6:02pm
Helstoon
Paul
Post #853145 30th Aug 2020 6:03pm
