Home > In Car Electronics > Cool Box Running Times
Greyman110
I'm going away for a few days and I'm borrowing a halfords cool box for the trip.
I recently added a couple of power sockets to the rear of the 110 that take the power from the constant live feed in the speaker panel.
I have a split charging system as well.
The question is how long can I leave this cool box plugged in for without killing my battery? I think I read somewhere that the draw is 3.5a.
As the live feed is from the cranking battery, should I link the leisure battery when the car isn't running?
Post #842068 6th Jul 2020 11:19am
Stacey007
Hello
I've used one on big trips and it's been fine, freeze the contents first if it's stuff you don't need straight away. If on a ferry or leaving the car for a few hours I did unplug it...didn't want the car not to start.
Last summer I used the same fridge all holiday off grid using a 120w sollar panel and leasure battery. In the day the battery topped up enough to run the fridge all night.
Post #842071 6th Jul 2020 11:41am
Bluest
I think that will be thermoelectric type box that will be running more or less continuously. They not ideal for this type of use.
For the sake of argument, if it is a 90ah AGM Battery you've probably got about 45ah of useable power, so you might be able to run the fridge for 12 ish hours. 3.5 amps X 12 = 42ah. Whether it would still have enough to start the motor after that, I don't know, but it could be marginal.
If you linked the batteries you would obviously have more reserve. 2007 110 TDCi Station Wagon XS
Post #842072 6th Jul 2020 11:43am
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
i use one of the halfords boxes occasionally i use a second battery in the back held in with a small ratchet strap to power the cool box and keep it charged by plugging it ito the cigarrete lighter, always remember to unplug it before switching off the ignitoin and plug it in after starting the engine that way there is no chance of flattening the main battery, a bit heath robinson but it works. i will get round to fitting something better sometime. nobody is perfect but being Scottish is a start
Post #842082 6th Jul 2020 12:25pm
Greyman110
Thanks for the replies.
That give me a much better idea of what I can and can’t do with this!
I do have a large separate leisure battery but I don’t have anything for it. Is there such a thing as a kit that I can attach to the battery to make it usable? I saw you can buy marine battery boxes but this battery is too big!
Post #842083 6th Jul 2020 12:26pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I would make a feed from the other battery.Does the cool box not have an automatic swith off at a low battery? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #842090 6th Jul 2020 12:50pm
Greyman110
Don’t think it has auto cutoff.
Think I might end up buying a proper fridge at some point...even though I’ll probably only use it once a year Rolling with laughter
Post #842093 6th Jul 2020 1:07pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I have one rear seat out with a Waeco mounted permanently. Only switch it out with the seat if really needed. Once you get used to it...
So get a proper fridge! Laughing
Post #842116 6th Jul 2020 3:37pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
SWMBO and I use a Halfords cool box for long warm/hot continental trips. We have found that the box is very well insulated and the addition of frozen food/freezer packs mean that we only run the cooler when the engine is running - 5 - 6 hrs a day. Just because you're offended doesn't mean you're right.
Post #842119 6th Jul 2020 3:54pm
