![]() | Home > Puma (Tdci) > HELP NEEDED - Wiper motor |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 ![]() ![]() ![]() |
do you mean the wiper motor or the two wiper spindles? also what year defender is it, answers to these questions will make it easier to help you.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
£88 ish
https://bearmach.com/front-wiper-motor-left-park-dlb500170x Rgds. Chris |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 125 ![]() ![]() ![]() |
Sorry 09 wiper motor |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
why does it have to be replaced?
Parking switch, and internal gear parts are (were?) available as new spares HTH Keith |
I thought if I have to take the dash off might as well replace the lot
Theres a really good step by step write up on here somewhere, not a massive job just fiddly.
I had a circlip come off the internal wheel, so I swapped out the park switch and fitted new wheel etc, pulled the rack out, turned wheel boxes 180 degrees greased everything and reassembled for under £25 IIRC Good luck! Keith |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
Bearmach 15% off this weekend:
