![]() | Home > Maintenance & Modifications > 300 Tdi 90 Rear Spring |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
Putting the springs in either way up will not affect their functionality or behaviour at all. However, I would fit them with the tighter coils at the top as this will make it easier to pressure wash off and stop any muck getting trapped in the bottom of the spring and rotting it and the spring seat out.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
I replaced some very worn springs on my old 90 with a set of new LR standard ones and it absolutely transformed it. I've just done a similar thing the same with my 110, albeit with a slightly different spec. and would do so again.
A worthwhile addition whilst changing springs are to add Discovery spring isolators to the tops. At the rear, Disco 1 ones and if doing the front, use those from a Disco 2 with built in turret ring and bolts. ![]() Click image to enlarge There's more details of all of the parts I used here: https://www.defender2.net/forum/post663510.html#663510 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
I have just fitted RKB101240 and RKB101230 to the rear of my 90 during a re-chassis. Not as firm as the Bearmach Blue springs that they replace so the rear is now sitting slightly lower than before. I have adjusted my Koni shocks to give a firmer ride so it will be interesting to see over the next couple of weeks (I am taxing the vehicle again on 1st July) how it behaves.
I have fitted spring isolators ANR2938 F&R, not certain if any difference will be noticeable but thought I would give them a try. ONE LIFE, GET IT! |
mpb Member Since: 30 Sep 2013 Location: Stafford Posts: 15 ![]() ![]() ![]() |
Thanks for the advise. I’ll get some ordered
