![]() | Home > Maintenance & Modifications > POR 15 on rear cross member |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Hi after some advice I am about to give the rear crossmember so tlc and rub back and repaint I want a good rust preventer and hard wearing gloss finish. Is POR 15 the best option can in be hand painted and leave a smooth finish or better sprayed.
Thanks in advance Andy Andy Defender 90 Defender 110 XS Cupra 290 |
POR15 is an excellent chassis paint but unless they've changed the formula, it's not UV stable and therefore not recommended for areas that could see direct sunlight. Darren
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
I did mine using POR15 kit last time, after reading recommendations here.
I had 2 tins (sorry can't remember what each was called), but the undercoat went on really nice, smooth, no brush marks. Then the top coat (which was probably the chassis black, meant to protect the undercoat from UV) was horrible to brush on, left brush marks but I did my best. Looked reasonably good afterwards but started to peel off the undercoat after around 18 months. After a couple of winters it was looking tatty again, and yes I did the best prep I could. I'll probably give Buzzweld a go next time. |
With por 15 you need to use the full system, so they have a degreaser to use first then a metal prep then the paint then top coat. As above the paint goes on nice but the brush on top coat isn’t brilliant so I use the paint followed by the spray on clear top coat that is uv stable
![]() One I did last week with por15 ![]() Click image to enlarge A before shot just for reference ![]() Click image to enlarge Edit: and after the metal prep stage, before painting. ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
