![]() | Home > Puma (Tdci) > Optimill window blocks |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3783 ![]() ![]() ![]() |
Window blocks and wing mirror arms are accessories. I’d like to see you pass an mot with either missing!! LR dealers really are atrocious.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
Accessories?!!!! I would be apoplectic with rage if they had said that to me. I think that might take extracting the urine to new levels, even for a car dealership. 2007 110 TDCi Station Wagon XS
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496 ![]() ![]() ![]() |
At least you won't be doing the job again a year later, like I had to when the approved body shop did mine.
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3657 ![]() ![]() ![]() |
What an absolute joke your dealer is?
Window blocks do look good now ![]() |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1070 ![]() ![]() ![]() |
If I were to start again, I'd just replace the originals on the day of purchase rather than wasting time talking to the dealer.
Do they have a slightly larger footprint at the top? It looks like they pinch down on the windscreen rubber?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
My local dealer changed and sprayed my window blocks just over a year ago under warranty as paint was bubbling.so can’t understand why yours said no.
It looks like you've got a bit of corrosion by the nearside windscreen block on the bulkhead. If it is I would sort it out now.
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
I changed mine last year mine bubbled could not be bothered to go to the dealer . I'm happy with mine
Mr Kington Member Since: 24 Dec 2024 Location: United kingdom Posts: 16 ![]() ![]() |
has anyone had issues with their optimil window blocks not fitting ? passenger side went straight on, drivers side only one bolt will fit. can either get one top one on, or one bottom one. very odd
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537 ![]() ![]() |
Sounds like you have two for the same side?
Garage have made them fit ! definately a complete set and one for each side. They were a complete PIA but he got it to work, think the internals of the skin was out. Just made it hard to line them up. I have made a mental note to never take them off ! only removed for paint correction and it does look very nice now.
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2278 ![]() ![]() |
Not optimil blocks but this mess has happened after fitting.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 367 ![]() ![]() ![]() |
Yes mine were a right pain to fit. The bolt pattern was correct but seemed to have been drilled slightly off. I managed in the end but took me a while. |
