Home > Td5 > No front drive
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
No front drive
So, what are the chances this is just the drive member? If so it’s a cheap fix, but before I pull it apart what is the thinking of those experienced in such broken things?
At this point I was going to upload a 10 second video of the front shaft turning inside the stationary drive member, but alas I don’t know how to. Anyway, you get the idea. Will I be lucky?
Post #838566 20th Jun 2020 7:46pm
If you can see the shaft turning in the drive member then you'll need to replace the member and probably the shaft.
Post #838569 20th Jun 2020 7:57pm
bankz5152
Pop the rubber caps off.
Youll see then.
If not its a shaft/CV (Usually makes a crunching noise) or diff also crunchy
Post #838584 20th Jun 2020 8:49pm
landy andy
If the front drive has failed it will probably be the cheese front diff. Done a few of them over the years. But it’s no biggy, it’s a great opportunity to bond with your truck. Thumbs Up Thumbs Up
Post #838591 20th Jun 2020 9:16pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If the splines on the drive member are gone, I am afraid that the splines on the shaft are not that good either. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #838592 20th Jun 2020 9:16pm
RoddyK05
Had a wee look and the splines on the drive member are just about non existent. I had a spare one from when I changed to 1 piece rear shafts so cleaned it up and popped it on. The shaft isn’t overly jaggy looking, it’s going now but definitely on my ‘to do sooner rather than later’ list. At least it keeps me mobile just now. Cheers for all the input Thumbs Up
Post #838599 20th Jun 2020 9:34pm
Change both CV's and drive hubs.... you'll be amazed how much less clunky the transmission will become
Post #838601 20th Jun 2020 9:41pm
RoddyK05
This sounds expensive. Any idea what kind of money is in that, although it certainly sounds like a good idea?
Post #838602 20th Jun 2020 9:44pm
jst
cvs arent much ,£50? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #838626 20th Jun 2020 11:02pm
RoddyK05
At that price it’s got to be done then. Are there any that should be avoided, I’m thinking blue box here, as it’s obviously going to involve a bit of work to get it all done. It’s not something I’d be wanting to re-visit in another couple of years at least. I’d be puting it into my local garage for the work but I always supply the parts so there is hopefully no messing around waiting on bits.
Post #838632 20th Jun 2020 11:11pm
bankz5152
Fairly heavy handed.
Yeah the CV is £50 but all thr seals and gaskets another £10, grease £5 and if your going that far may aswell do wheel bearings ,£14.
Post #838636 21st Jun 2020 12:05am
jst
^^^^ depends on mileage ref bearings I would suggest. Seals you can use rtv. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #838674 21st Jun 2020 8:13am
lightning
As suggested above,
I changed the rear drive shafts and all four drive members on my 90 TD5 and what a difference, so much nicer to drive with most of the slack removed from the transmission.
On yours, if one of the drive members has completely worn out then l bet the other three are past their best as well. Don’t forget to fit the paper gaskets when you do the drive members!
Post #838680 21st Jun 2020 9:11am
roel
If you don't have ABS try to get the none ABS version as the are stronger. I went for Ascroft they are a bit Whistle more expensive but till now the last.
I broke a few standard ones. Roel
Post #839254 23rd Jun 2020 9:47pm
RoddyK05
Having a look at CV kits, it is mostly Britpart that is popping up. Would these be ok or are there better versions available? Yes Ashcroft would be the dream but as Roel has pointed out they are big £££! Can anyone point me in the direction of a decent kit and maybe even a supplier of such?
Post #839274 24th Jun 2020 12:06am
