Home > Td5 > Oil Depression Control Valve
excossack
What does the Oil Depression Control Valve do? Is it a one way valve i,e stops flow from the turbo going into the rocker cover/cam area?
I noticed mine appears to have a slight leak (a drip or three of oil below it in the air pipe. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #838463 20th Jun 2020 11:12am
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Works the opposite way round gases from the engine come from the rocker cover and at a set vacuum pressure the dpv opens allowing the engine to breathe and those oily gases go into the intake and handily coat the inlet pipes inter cooler and egr and inlet manifold they do get oily there maybe a replacement is needed not difficult to do and fairly cheap hope that helps
Post #838519 20th Jun 2020 2:18pm
excossack
Cheers Sicastle71.
Should gases from the turbo be allowed down the pipe into the rocker cover area?
After ages spent trying to stop oil leaks from the rocker cover, I am just seeing if i have missed any other ideas. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838721 21st Jun 2020 1:39pm
Sicastle71
No it’s before the impeller on the turbo the gases from the rocker cover get sucked into the turbo imagine the turbo is a motor in a hoover and the gases coming from the rocker cover are sucked in. The depression valve opens at a set vacuum pressure as it has a diaphragm inside as said part is easy to replace as diaphragm can fail you can try cleaning the area up to check if the oil accumulates again hope that helps you out. Where is the oil leaking from out of interest
Post #838738 21st Jun 2020 3:32pm
excossack
Hi. Cheers for the info.
Leaking, as always from rear half moon seal.
With sealant or without. Genuine LR or aftermarket, various sealants and still leaks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838739 21st Jun 2020 3:48pm
Sicastle71
Ah right you need to check that the area is clean chance are the seal is not seating right tighten the rocker cover bolts in a pattern as if you were doing a cylinder head up ie opposite to opposites starting from the centre bolts they do not need to be really tight where the half moon is try some grease to hold it in place and try to seat into the radius they can be a Censored to get right sorry
Post #838752 21st Jun 2020 4:51pm
excossack
Yup, cleaned, bolts tightend in the correct sequence, to correct torque.
Added sealant to both sides of the gasket and left to go off for a couple of days and still leaks.
Which is why I was looking at the breather hose thinking could this be blocked/restricted causing a build up of pressure ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #838760 21st Jun 2020 5:37pm
Sicastle71
Could well be the depression valve is blocked or not working correctly I would replace it and try that as it won’t be allowing the gases in the engine to escape they are not expensive to replace and I believe many view them as a service item only a two minute job to do
Post #838767 21st Jun 2020 5:58pm
excossack
cheers, I think fo the price I will get one on order. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838768 21st Jun 2020 5:59pm
Sicastle71
Yeah as said if it’s not working could be pressurising the engine causing the leak at the half moon seal and build up of oil at thr valve
Post #838770 21st Jun 2020 6:08pm
excossack
Item purchased. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838799 21st Jun 2020 9:07pm
