Home > Maintenance & Modifications > Water Leak
TheShrink
Water Leak
Hi All,
Can anyone help identify what might be causing this leak, as shown in the picture?
It’s not coolant and I can’t see anything obvious in the engine bay.
Remember you are responding to a novice!
Thanks
Post #837197 14th Jun 2020 7:56pm
90 Dreamer
No pic??
Post #837198 14th Jun 2020 8:00pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi The Shrink could it be the run off from you’re air con Thumbs Up if so it’s normal cheers Paul
Post #837571 16th Jun 2020 5:39pm
landy andy
What engine?
Are you talking about this drip?
I would feel it a if it dose it feel oily? Does it smell? If neither I would then taste it. Coolant has a vey particular taste and condensation has no taste.
Post #837629 16th Jun 2020 9:00pm
TheShrink
Yes you have spotted the drip which is coming from the area marked with an arrow.
I put a bucket underneath to collect the water. It looks like plain water - not coolant and has no taste. I did notice that coolant is very low in header tank but I’m not sure this is related. If it was i assume what i collected would be coolant, which its not.
Just makes no sense to me. I have taken it for a drive to see if that did anything and even afterwards it still dripped.
I wish I was mechanically knowledgeable but really appreciate people taking the time to respond. Great website.
Thanks
Post #837635 16th Jun 2020 9:21pm
landy andy
Are you using your air conditioning whilst driving it?
If yes it will probably condensation on the AC condenser which is mounted with the cooolant rad, which is directly above those drips.
Post #837645 16th Jun 2020 9:31pm
TheShrink
I have air con but haven’t used it.
Post #837647 16th Jun 2020 9:34pm
landy andy
Odd. All I can say to help is, if it was any important fluid, it would taste, smell, or be oil.
Sorry I’m stumped, but will think on, and let you know if any ideas.
Is this on a Tdci?
Post #837655 16th Jun 2020 9:50pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
The only other water in there that I can think of would be from the windscreen washer bottle and pipe work.
Post #837663 16th Jun 2020 10:11pm
TheShrink
Is this on a Tdci?
Thank you, Landy Andy - i appreciate it. It is a Tdci.
Post #837669 16th Jun 2020 10:22pm
