Home > Maintenance & Modifications > TD5/TDCI auxillary switch alternatives? |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
I have converted HRW switch
30th May 2020 11:50am |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 205 |
That switch is doing my heated windscreen.
All my switches are doing something now There is 2 blank holes left which I could modify for normal switch. Just wanted to keep it looking orginal. |
30th May 2020 12:05pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I might be unlucky, but I have had the backlight and led illumination fail twice on non-genuine repro spot light switches. Both failed after not much time. I don’t know if there was ever a genuine LR switch in the type you need, but I would say it is worth the extra if there is. 2007 110 TDCi Station Wagon XS
30th May 2020 12:29pm |
There will almost certainly be a LR switch that can perform the same function but not with the nice graphic on it. It is now possible to buy just the switch covers with different graphics on but they're about £10 each. If you then have to buy a LR switch as well, even second hand, then it does make for an expensive combination. Darren
30th May 2020 4:59pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 486 |
The best (and cheapest) combination is to use a Genuine Puma heated seat switch - YUF500150LNF
With the Bearmach switch front of your choice. Bearmach have a 20% flash sale on right now - Finishes at 8pm today Use Code: BMSATUR20 Martin can supply the black 5-way connector and terminals from his webshop. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
30th May 2020 7:04pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Bought a couple of the genuine heated seat switches a while back in preparation for a project. Rimmer Bros were the cheapest source then, not sure now though?
https://rimmerbros.com/Item--i-YUF500150LNF |
30th May 2020 7:25pm |
The HRW switch is wired exactly the same as the Puma heated seat switch, but uses the blue 5-way connector. The TD5 (Defender and Discovery-2) heated seat switches, as well as the Discovery-2 cruise control switch are also wired the same. RH heated seat switch uses the black connector LH heated seat switch uses the green connector Cruise control switch uses the white connector . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
30th May 2020 7:45pm |
