![]() | Home > In Car Electronics > Alpine subwoofer disassemble |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496 ![]() ![]() ![]() |
It's nothing difficult, remove the 4 fasteners from inside the cubby box and gently remove the sub. I think they were just bolts under the plastic caps. The electrical connections are on the face that mounts to the cubby, but you shouldn't have to disconnect anything.
Use the steel plate as a template to drill the holes in the new cubby from the outside, then refit it inside the box. ![]() |
Lander2015 Member Since: 15 Aug 2015 Location: aberdeen Posts: 8 ![]() ![]() ![]() |
Managed great outcome, as you stated no need to disconnected The only surprise was the replacement cubby box was slightly longer by 1.5 cm Cheers |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Yes, the subwoofer version of the cubby is slightly shorter. Strange how LR bothered to change things like this
