Home > Td5 > Fuel gauge needle swaying on bends |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 897 |
Its the gauge ormthe sender unit not the tank. Check your grounds...”earths” to start 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
27th May 2020 2:09am |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
Friend of mine has a similar issue with his gauge although not changing on bends but on bumps. Found that when the fuel pump was unplugged the main earth pin on the pump was pushed through the top of the pump and no longer connected. Reckones the pump was trying to find an earth through the gauge therfore causing issues. Quick fix but took him a while to access it. Whatever and wherever it is I agree with 4RF. it definitely sounds like an earth problem.
27th May 2020 3:43am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6031 |
Mine does this, but only because I've bypassed the fuel needle dampening part that is in the speedo head, as mine is duff and under-reads below about 3/4 tank.
It's like driving my old series 2 again, so I'm Ok with that |
27th May 2020 7:44pm |
Don't worry about getting air in the system, from experience I know that you can easily idle and drive slowly for more then 15 minutes with the first stage off the pump not getting any fuel.
Click image to enlarge And then it died. After being pulled out it almost directly started again, so no worries. About your problem, It could be an earth problem but why does it go low on a right bend and high on a left bend? I am not sure if the pump can be oriented differently in the tank as mine reacts on nose up or down. However it reacts slowly only when I am really stationary on an incline. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
28th May 2020 6:43pm |
