![]() | Home > Off Topic > Folk knowledgeable about petrol lawnmowers |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
Just in the process of giving my petrol lawnmower a service and blade change. I’ve noticed the mower has been harder to start recently and finds any kind of resistance in the grass tough going. The blade turns (relatively) freely for four turns then gets hard to turn. Is this normal or should it turn freely? If freely, what would the cause of the jarring be? Note that I’ve engaged the handle to release the small brake pad off the Counter-weight brake surface.
Thanks in advance ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4318 ![]() ![]() ![]() |
If it's a 4 stroke, every second turn should feel resistance as compression builds in the cylinder. After the piston reaches top dead centre you should suddenly feel the resistance go.
Note that this is only the case if the spark plug is fitted. If it is, be careful turning it over, you don't want it starting by accident ![]() For you running problems, start with the basics. Check the plug gap, check the sir filter is clean. Squirt some carb cleaner in the throttle. Make sure the fuel is fresh and stick a dose of fuel system cleaner in like Redex.. 2007 110 TDCi Station Wagon XS |
r500sac Member Since: 28 Mar 2014 Location: Monmouth Posts: 36 ![]() ![]() ![]() |
Search for Mustie1 on YouTube, he'll teach you all there is to know about petrol mowers!
Thank you all.
![]() It is direct to motor with belt driven rear wheels. I’ve given it a good dig out, cleaned and balanced the spark plug, checked filter (clean as a whistle) and adjusted the carb a little (we live at altitude). I’ve given everything a good grease. I’ll replace and adjust the started cord. Re the turn, yes, it gets progressively harder, then releases and then goes through the process again, so I can only assume it is compression as mentioned by Bluest. I’ll check out Mustie 1 just to be sure. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
If it's. Struggling then that would be a fuel issue.
I sugest remove carb and make sure the bowl is clean an also the jets as these block easily especially with stale fuel ![]() |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
You want to try running a fuel stabiliser or additive that cleans through the system.
I use one ( can’t remember the name but will go & look ). Basically you use it instead of petrol at the end of the season. Run your tank dry & then add this & run your engine. It protects seals etc & allows the engine to be started at a later date much more readily. They are not cheap;about£15 a gallon Guy May your life be like toilet paper ; long & useful. |
Aspen 2 ( for 2 stroke engines) & Viking make one called Motorplus.
I am sure there are plenty of others Guy May your life be like toilet paper ; long & useful. |
Thank you again. Will check the carb. Heading to the DIY store today, will look for some cleaner and at the end of the season, some of the additive mentioned. Ta. Monsieur Le Grenadier
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Have you tried turning by hand with the spark plug removed ? Mine had the same symptoms, I was concerned while turning the blades by hand until I removed the spark plug and it turned freely and I realised it was just the compression. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
