- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Vitesse
Speedo transducer O ring replacement | |
Hi..Anyone know the best way to get the speedo transducer housing out easily? I need to change the O ring. I have removed the electronic sensor part but cant see how the centre section comes out. Its very tight to access with the brake drum etc... Is there a special tool/ trick or method to use or do I need to make more room for access?
Thanks.. 2015 90 XS Santorini Black
14th May 2020 3:51pm |
